方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A controlled stress rheometer with normal force measurement capability was used to screen a series of liquid pressure sensitive adhesives. The samples were processed in a roll coating application with a pattern bar producing controlled bands of the final coating. Some samples coated well, but others produced surface irregularities such as ribbing or beading and were considered to have failed. Conventional viscometry could not predict which samples were likely to perform well and which were likely to fail. The use of rheometry proved more successful and by calculating certain dimensionless groups, the samples could be ranked in order of suitability. Surface tension information proved to be less relevant than overall viscoelastic data as provided by measurement of normal stress in the fluid under steady simple shear.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
