方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | Arrhenius |
It is well known that there is an equivalence of the effects of time and temperature on the rheological properties of viscoelastic materials1. At low temperatures a material will behave in the same fashion as at high frequency, and at high temperature the material will behave as it would at low frequency. Data in a range of temperatures over modest frequency ranges( see figure 1) can be collected and arranged to predict the behavior over a wider frequency range than possible in practical testing. Bear in mind that very low frequencies can take days or weeks for measurements, and ultra high frequencies cannot be measured by existing instruments. The modulus data can then be shifted horizontally along the abscissa to overlap forming a smooth curve. This approach allows the generation of master curves of modulus data spanning considerably wider ranges of time (frequency) and/or temperature than the range of the original data (see figure 2).
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
