方案下载应用领域 | 电子/电气 |
检测样本 | 其他 |
检测项目 | |
参考标准 |
Modulated DSC is a powerful tool for materials characterization. Like any other precision technique, failure to use the optimum experimental conditions can result in sub-par performance. Following the suggestions listed in this paper should help you to design your MDSC experiment so that you derive the highest quality data.
INTRODUCTION
Modulated DSC (MDSC®) provides a powerful enhancement to the standard DSC experiment. MDSC can simultaneously improve the sensitivity and resolution of the DSC experiment, in addition to providing heat capacity and heat flow in a single experiment. In order to obtain the maximum benefit from the MDSC experiment, however, optimal MDSC conditions must be chosen. In this paper we examine the protocol for choosing the correct MDSC conditions with respect to sample size, modulation period, underlying heating rate, and modulation amplitude.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
