方案下载应用领域 | 电子/电气 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 测量 |
In an oscillation shear experiment, the material is subjected to either a sinusoidal strain or stress and the corresponding response is measured. The ratio of the output and input signals is referred to as the transfer function or material function (Figure 1). When a sinusoidal deformation or deformation rate is applied, the material’s response is the stress. The resulting material function is either the modulus or the viscosity; if a stress is applied and the strain measured, the material function is the compliance.
利用微量热技术研究病毒结构与宿主细胞受体结合反应
等温量热法研究水泥水化
等温微量热法研究生物制品长时间稳定性评价
