瑞典安玛西亚Monitor UV-MⅡ紫外检测器(半价优惠)
1、Microprocessor-based,high-precision single-beam absorbance detector primarily intend for use with FPLC systems.
2、Ideal for gradient elutions since the double cone 5 mm flow cell excludes refractive indexes effects.
3、The Optical Unit can be placed adjacent to the column for minimal dead volume effects.
4、A choice of mercury or zinc lamps and eight filters covers the range of wavelengths from 214 to 546 nm.The filters are easily selected using the rotary filter wheel.
5、The microprocessor within the Control Unit coordinates auto-zero,event mark,and baseline adjustment with self-diagnostics and remote control.
优惠价格:$4500(原价:$12000)
阅读2188次
已关注
