今天给大家分享的是2014年4月份 《Chemical Engineering Journal》上发表的一篇名为:Effect of support on the deep oxidation of propane and propylene on Pt-based catalysts
文章摘要如下:
The complete oxidations of propane and propylene were studied on Pt supported on CeO2, TiO2 and Al2O3. The catalyst activities were evaluated through conversion versus temperature (light-off curves) and conversion versus time tests. Propane oxidation turnover rates (TOF) followed the order: Pt/TiO2 > Pt/CeO2 > Pt/Al2O3. The higher activity on Pt/CeO2 than on Pt/Al2O3 was interpreted by considering that the combustion of C3H8 on Pt/CeO2 occurs not only on Pt0 sites but also on perimeter Pt0–Ce3+ sites providing an additional oxidation pathway. Propane uptake on Pt/TiO2 was 5.5 times higher than on Pt/CeO2. This drastic increase of the density of adsorbed C3H8 molecules around the metallic Pt active sites would explain the high TOF values observed on Pt/TiO2 because the reaction is positive order with respect to propane. The propylene oxidation turnover rate trend was Pt/CeO2 > Pt/Al2O3 ? Pt/TiO2. Kinetic studies showed that on the three catalysts the apparent activation energy of propylene oxidation was about the same while the reaction orders were positive in oxygen and negative or zero in propylene. The higher activity of Pt/CeO2 catalyst was explained by considering that the Pt-catalyzed reduction of ceria forms oxygen vacancies that would improve the mobility of lattice oxygen of the support and its transfer to the propylene species adsorbed on the metal.
该文章中材料表征采用的是美国麦克仪器AutoChem 2920
详情可参考下面链接:
http://www.sciencedirect.com/science/article/pii/S1385894713015787
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
