今天给大家分享的是2014年4月份 《Separation and Purification Technology》上发表的一篇名为:Catalytic oxidation of nitrobenzene by copper loaded activated carbon
文章摘要如下:
In the present study, catalytic wet peroxidation (CWPO) process has been applied for the degradation of nitrobenzene bearing wastewater using copper impregnated granular activated carbon with hydrogen peroxide as oxidant. Various catalysts were prepared by varying the Cu loading on activated carbon and these were characterized by N2 adsorption–desorption, Fourier transform infrared spectroscopy (FTIR), field emission scanning electron microscope (FE-SEM), thermogravimetric analysis (TGA), temperature programmed reduction (TPR) and UV–visible diffuse reflectance spectra (UV-DRS). Effect of parameters such as copper loading, pH, catalyst dose, hydrogen peroxide dose and temperature were explored on nitrobenzene and total organic carbon (TOC) removal. TOC removal of 89% was achieved after 4 h treatment at optimum condition of Cu loading = 2.5 wt%, pH ≈ 3.0, catalyst dosage = 0.25 g/l, oxidant dosage = 4.5 (moles of oxidant/moles of NB) and temperature = 55 °C.
该文章中材料表征采用的是美国麦克仪器AutoChem 2920
详情可参考下面链接:
http://www.sciencedirect.com/science/article/pii/S1383586614000781
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
BTA亮点有多少?直播、视频、好文......一网打尽
拿捏了!双蒸汽穿透吸附全方位直播
