今天给大家分享的是2014年4月份 《Journal of Power Sources》上发表的一篇名为:Methanol synthesis from CO2 hydrogenation over La–M–Cu–Zn–O (M = Y, Ce, Mg, Zr) catalysts derived from perovskite-type precursors
文章摘要如下:
A series of La–M–Cu–Zn–O (M = Y, Ce, Mg, Zr) based perovskite-type catalysts are prepared by sol–gel method and characterized by XRD, BET, TPR, N2O-adsorption, XPS and TPD techniques. The results indicate that all the catalysts exhibit La2CuO4 perovskite structure. The addition of Ce, Mg and Zr lead to smaller particles, lower reduction temperature, higher Cu dispersion, larger amount of hydrogen desorption at low temperature and more amount of basic sites. However, Y has less affects on the physicochemical properties. The catalysts derived from perovskite-type precursors show high selectivity for methanol, which is correlated with the Cuα+ species that exists in the reduced catalysts. More exposed Cu surface area is favorable for high CO2 conversion.
该文章中材料表征采用的是美国麦克仪器AutoChem 2920
详情可参考下面链接:
http://www.sciencedirect.com/science/article/pii/S0378775313018648
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
