每周分享:Effect of support-active phase interaction on the catalyst activity and selectivity in deoxyenation of triglycerides
今天给大家分享的是2014年2月份《Applied Catalysis B:Environmental》上发表的一篇名为:Effect of support-active phase interaction on the catlyst activity and selectivity in deoxygenation of triglycerides
文章摘要如下:
Three industrially important supports,SiO2,TiO2 and Al2O3,were used for preparation of NiMo catalysts(3.3 wt.% Ni and 15.0 wt.% Mo) and in deoxygenation of rapeseed oil in presence of hydrogen (3.5 MPa) at 260-300℃ and liquid feed weight-hourly space velocity in the range 2-8 h-1.Due to the same method of preparation and activition (sulfidation) of the catalysts,the final properties were affected mainly by the differences in the nature of supports as well as their properties,such as specific surface areas,pore size distribution or acidity.Most notably the dispersion of the active phase decreased in the following order Sio2>Al2O3>TiO2. As a result,the SiO2-supported NiMo catalyst exhibited smaller extent of hydrogenation reactions and a larger extent of decarboxylation.On the other hand ,the TiO2-supported NiMo catalyst exhibited increased selectivity to hydrodeoxygenation products,plausible due to the larger active phase cluster size and broad pore size distribution.The results provide clear evidence that even with the conventional hydrotreating active phase,such as sulfided NiMo,the selectivity can be fine-tuned by support selection and modificatin
该文章中材料表征采用的是美国麦克仪器AutoChem2920
详情请参考下面链接:
http:www.sciencedirect.com/science/article/pii/S092633731300028
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
