每周分享:Influence of alkaline and alkaline-earth cocations on the performance of Ni/β-SiC catalysts in the methane tri-reforming reaction
今天给大家分享的是2014年4月份 《Applied Catalysis B: Environmental》上发表的一篇名为:
文章摘要如下:
The influence of alkaline (Na, K) and alkaline earth (Mg, Ca) cocations on the behaviour of Ni/β-SiC catalyst for the tri-reforming of methane has been evaluated in this work. The cocations were loaded by co-impregnation with Ni, using different cocation/Ni ratios. Catalysts were characterized by AAS, TPR, N2 adsorption, CO2-TPD and XRD after calcination, as well as by XRD and TPO after reaction. It was analyzed the effect of the cocations on the β-SiC oxidation rate, which was increased when Na or K were loaded. The presence of Mg led to a high catalytic performance and stability (with a lower coke formation) since it provoked a decrease of Ni particle size and an increase of both the interaction between nickel and promoter and the catalyst basicity. Catalysts with Ni:Mg molar ratios of 2/1 and 1/1 showed the best performance in terms of activity and stability and formation of coke. These catalysts were considered good candidates for the tri-reforming of methane.
该文章中材料表征采用的是美国麦克仪器AutoChem 2950 HP
详情可参考下面链接:
http://www.sciencedirect.com/science/article/pii/S092633731300698X
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
