今天给大家分享的是2014年6月份 《ACS Appl. Mater. Interfaces》上发表的一篇名为:Role of Polyaniline on the Photocatalytic Degradation and Stability Performance of the Polyaniline/Silver/Silver Phosphate Composite under Visible Light
文章摘要如下:
Polyaniline/silver/silver phosphate (PANI/Ag/Ag3PO4) composite was prepared by in situ depositing silver phosphate (Ag3PO4) nanoparticles on the surface of polyaniline (PANI). The best photocatalytic Rhodamine B degradation performance is obtained by the 20 wt % PANI/Ag/Ag3PO4 composite, which is approximately 4 times higher than that of pure Ag3PO4. Meanwhile, the photocatalytic stability of Ag3PO4 is significantly improved by introducing PANI into the PANI/Ag/Ag3PO4 composite. The dramatic promotion of the photocatalytic degradation performance and the photocatalytic stability can be attributed to the formation of a heterojunction electric field between PANI and Ag3PO4, which is approximately 90 mV and points from Ag3PO4 to PANI. The existence of this electric field can dramatically enhance the separation efficiency of the photogenerated electron–hole pairs, accelerate the transfer of photogenerated holes from Ag3PO4 to PANI and therefore inhibit the self-oxidation of Ag3PO4
该文章中材料表征采用的是美国麦克仪器3Flex
详情可参考下面链接:
http://pubs.acs.org/doi/abs/10.1021/am503578s
老朋友新面貌:AutoChem III 2930 化学吸附仪深度解读,直播带您一探究竟
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
