今天给大家分享的是2015年5月份 《RSC Advances 》上发表的一篇名为:Synthesis of magnetic porous γ-Fe2O3/C@HKUST-1 composites for efficient removal of dyes and heavy metal ions from aqueous solution
文章摘要如下:
A novel and inexpensive approach was adopted to develop magnetic porous γ-Fe2O3/C@HKUST-1 composites for the adsorption of dyes and heavy metal ions from aqueous solution. The γ-Fe2O3/C with unique functional groups present such as –OH and –NH2 was used as the support to directly grow HKUST-1 by a stepwise liquid-phase epitaxy process. The crystallographic, morphology, and magnetic properties as well as porosity of the as-synthesized γ-Fe2O3/C @HKUST-1 composites were carefully studied by XRD, SEM, TEM, XPS, TGA, and BET. The results indicated that the BET surface area, micropore volume, and saturation magnetization of the γ-Fe2O3/C @HKUST-1 are 993.4 m2 g?1, 0.69 cm3 g?1, and 12.6 emu g?1, respectively. In addition, a uniform distribution of ultrafine γ-Fe2O3 nanoparticles with an average diameter of 2–3 nm was observed in the γ-Fe2O3/C@HKUST-1 composites. Our results showed that methylene blue (MB) and Cr(VI) (used as a model for typical dye pollutants and heavy metal ions) are effectively removed from aqueous solutions by γ-Fe2O3/C@HKUST-1. The maximum adsorption capacities were 370.2 and 101.4 mg g?1 of adsorbent for MB and Cr(VI), respectively. Moreover, a removal efficiency of about 90% was retained after five cycles of consecutive adsorption–desorption. The adsorption kinetics data were well described by a pseudo-second-order model (R2 > 0.99), and equilibrium data were well fitted to the Langmuir isotherm model (R2 > 0.99). Finally, our results suggested that the γ-Fe2O3/C@HKUST-1 composites have a great potential to be employed for treatment of wastewater containing MB and Cr(VI).
该文章中材料表征采用的是美国麦克仪器3Flex
详情可参考下面链接:
http://pubs.rsc.org/en/content/articlelanding/2014/ra/c4ra12468e#!divAbstract
老朋友新面貌:AutoChem III 2930 化学吸附仪深度解读,直播带您一探究竟
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
