今天给大家分享的是2015年5月份《RSC Advances
》上发表的一篇名为:Facile synthesis and supercapacitive properties of Zr-metal organic frameworks (UiO-66)
文章摘要如下:
Metal organic frameworks (MOFs), a kind of crystalline porous material, have attracted much attention due to their high surface area and controllable porous structure. In this paper, we present a new synthesis of Zr-based MOFs with high electrochemical performance by a facile synthetic method of changing the reaction temperature and stirring condition. By varying the reaction temperature, different particle sizes and degrees of crystallization can be obtained. This paper focuses on the electrochemical properties of Zr-based MOFs as electrode materials in supercapacitors. The maximum specific capacitance of Zr-MOF1 obtained at 50 °C can reach up to 1144 F g?1 at a scan rate of 5 mV s?1, which is far higher than Zr-MOF2 (811 F g?1), Zr-MOF3 (517 F g?1) and Zr-MOF4(207 F g?1). The results of electrochemical measurements show that the Zr-MOF1 we synthesized has excellent capacitance performance and good cycling stability over 2000 cycles, which makes it a promising supercapacitor electrode material.该文章中材料表征采用的是美国麦克仪器ASAP 2460
详情可参考下面链接:
http://pubs.rsc.org/en/content/articlelanding/2015/ra/c4ra11896k
老朋友新面貌:AutoChem III 2930 化学吸附仪深度解读,直播带您一探究竟
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
