今天给大家分享的是2015年4月份《Original Paperl》上发表的一篇名为:Synthesis of amino-functionalized mesoporous materials with environmentally friendly surfactants by evaporation-induced self-assembly and their application to the adsorption of lead(II) ions
文章摘要如下:
Five amino-functionalized mesoporous materials were directly synthesized by an evaporation-induced self-assembly method. A series of environmentally friendly surfactants as templates were used, including dimethyl dioctadecyl ammonium bromide, polyethylene glycol (PEG), alkyl polyglucoside, and cetyl dimethyl betaine, in order to reduce damage to the environment in templates elution during the synthesis process. These samples were found to have two-dimensional hexagonal mesoporous structures and worm-like pores characterized by small-angle X-ray diffraction and transmission electron microscopy. Larger mesoporous pore sizes (9.8–17.9 nm) and pore volumes (0.443–0.652 cm3 g?1) were determined by N2 adsorption–desorption. Amino-functional groups were modified onto mesoporous materials, which were proved by fourier transform infrared spectroscopy and elemental analysis. PEG-S (synthesized by PEG) had the biggest pore size (17.9 nm), the highest nitrogen content (4.237 %) and relatively large pore volume (0.507 cm3 g?1) among five samples. Adsorption of Pb(II) onto five mesoporous samples differed greatly at initial concentration ranging from 0.3 to 2.6 mmol L?1. PEG-S had largest adsorption capacity, with maximum adsorption capacity being 1.166 mmol g?1 (241.36 mg g?1) in initial 1.6 mmol L?1 Pb(II) concentration. PEG is nontoxic and readily biodegradable, and PEG-S displayed the maximum adsorption capacity in the study. Therefore, PEG-S samples were selected for processing lead ions. Then further study was made to investigate lead ions adsorption isotherm, the effect of pH value on the adsorption, as well as the reuses of adsorbents.该文章中材料表征采用的是美国麦克仪器ASAP 2460
详情可参考下面链接:
http://link.springer.com/article/10.1007/s10853-015-8832-4
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
