近日,美国麦克仪器公司首席科学家Jeffrey Kenvin博士与资深科学家Jacek Jagiello博士在Journal of Colloid and Interface Science期刊上共同发表了题为Consistency of carbon nanopore characteristics derived from adsorption of simple gases and 2D-NLDFT Models. Advantages of using adsorption isotherms of oxygen (O2) at 77K的文章。
在本文的研究中,作者尝试采用O2来进行气体吸附,因为据相关研究报道,O2的四极矩值小于N2的三分之一,因此其与极性基团的特定相互作用远小于N2。为了验证此结论,选用4种典型的多孔碳,分别测在77k和87K下的O2和N2吸附,得到孔径分布(PSD)与上述结论相一致。本文中PSD(孔径分布)计算采用了2D-NLDFT吸附模型。
该文章的摘要如下:
The pore size distribution (PSD) of porous carbons is most often derived from the analysis of standard N2 and Ar adsorption isotherms measured at 77 and 87?K. From the two gases, Ar is recommended (IUPAC Technical Report 2015) as more reliable for the PSD analysis due to its minimal specific interactions with the surface polar groups. Such interactions may influence the adsorption of N2molecules due to its significant quadrupole moment. In practice, however, using liquid Ar as a cryogen for Ar adsorption measurements may be challenging because of its high cost and limited availability in various parts of the world. In this study, we propose using O2 adsorption isotherms for the PSD characterization of porous carbons. The quadrupole moment of O2 is less than one-third of the value reported for N2, and thus its susceptibility to specific interactions with polar groups is much smaller than that of N2. We demonstrate a quantitative agreement between the PSD results derived from the adsorption isotherms of O2 and N2 measured at 77K, and Ar at 87K on four representative carbon samples. The PSD calculations are performed using adsorption models based on the two-dimensional non-local density functional theory (2D-NLDFT).
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
