AutoChem II 2920被引用的文章列表(注:由于篇幅的限制,只列出一小部分供参考)
文章标题 | 作者 | 刊物 |
Supported bimetallic AuRh/γ-Al2O3 nanocatalyst for the selective catalytic reduction of NO by propylene | Licheng Liu, Xiao Guan, Zhimei Li, Xuehong Zi, Hongxing Dai, Hong He | Applied Catalysis B: Environmental,90(1-2), Pages 1-9, 2009 |
Catalytic combustion of styrene over copper based catalyst: Inhibitory effect of water vapor | Hongyan Pan, Mingyao Xu, Zhong Li | Chemosphere,76(5),721-726,2009 |
Thermally Stable CeO2–ZrO2–La2O3 Ternary Oxides Prepared by Deposition–Precipitation as Support of Rh Catalyst for Catalytic Reduction of NO by CO | Fulan Zhong, Yihong Xiao, Ximing Weng, Kemei Wei, Guohui Cai, Yong Zheng and Qi Zheng, | Catalysis Letters,133(1-2), 125-133, 2009 |
Manganese-promoted cobalt oxide as efficient and stable non-noble metal catalyst for preferential oxidation of CO in H2 stream | Qinghong Zhang, Xianhong Liu, Wenqing Fan, Ye Wang | Applied Catalysis B: Environmental, 102(1-2),207-214,2011 |
Research on assembly of nano-Pd colloid and fabrication of supported Pd catalysts from the metal colloid | Licheng Liu, Ting Wei, Xuehong Zi, Hong He Hongxing Dai | Catalysis Today, 153(3-4),162-169,2010 |
Co/Pillared Clay Bifunctional Catalyst for Controlling the Product Distribution of Fischer−Tropsch Synthesis | Qing-Qing Hao, Guang-Wei Wang,hao-Tie Liu, Jian Lu, and Zhong-Wen Liu | Ind. Eng. Chem. Res., 49 (19), 9004–9011, 2010 |
Towards understanding the microstructures and hydrocracking performance of sulfided Ni–W catalysts: Effect of metal loading |
Guoqi Cui, Jifeng Wang, Hongfei Fan, Xiaoyan Sun, Yan Jiang, Shaojun Wang, Dan Liua, Jianzhou Gui | Fuel Processing Technology,92(12), 2320-2327,2011 |
Influence of Noble Metals on the Direct Oxidation of Ethylene to Acetic Acid over NM/WO3-ZrO2 (NM = Ru, Rh, and Pd) Catalysts | Lixia WANG, Shuliang XU, Wenling CHU,Weishen YANG | Chinese Journal of Catalysis, 30(12), 1281-1286,2009 |
Improvement of CO2 adsorption on ZIF-8 crystals modified by enhancing basicity of surface | Zhijuan Zhang, Shikai Xian, Hongxia Xi, Haihui Wang, Zhong Li | Chemical Engineering Science, 66(20), 4878-4888,2011 |
Highly efficient Pd/Al2O3-Ce0.6Zr0.4O2 catalyst pretreated by H2 for low-temperature methanol oxidation | Yongjin Luo, Yihong Xiao, Guohui Cai, Yong Zheng and Kemei Wei | Catal. Sci. Technol., 1, 1362-1366,2011 |
Palladium-Based Catalyst without Interlayer Film Prepared by Electroless Plating for Catalytic Combustion of Toluene |
Advanced Materials Research, 957,197-198, 2011 | |
Hydrodealkylation of C9+ Heavy Aromatics to BTX over Zeolite-Supported Nickel Oxide and Molybdenum Oxide Catalysts | Qunbing Shen, Xuedong Zhu, Jiaojiao Dong and Zibin Zhu | Catalysis Letters , 129(1-2), 170-180, 2009 |
Morphology effects of nanocrystalline CeO2 on the preferential CO oxidation in H2-rich gas over Au/CeO2 catalyst | Guangquan Yia, Zhongning Xub, Guocong Guob, Ken-ichi Tanakac, Youzhu Yuan | Chemical Physics Letters,479(1-3), 128-132,2009 |
Palladium supported on hierarchically macro–mesoporous titania for styrene hydrogenation | Tian-Ying Zeng, Zhi-Ming Zhou , Jun Zhu, Zhen-Min Cheng, Pei-Qing Yuan, Wei-Kang Yuan | Catalysis Today,147(S41-S45), 2009 |
Dehydrogenation of ethylbenzene to styrene with CO2 over iron oxide-based catalysts | Min Jia, Guili Chena, Junhu Wangb, Xinkui Wanga, Tao Zhang | Catalysis Today,158( 3-4), 464-469, 2010 |
Diffusion-enhanced hierarchically macro-mesoporous catalyst for selective hydrogenation of pyrolysis gasoline | Zhiming Zhou, Tianying Zeng, Zhenmin Cheng, Weikang Yuan |
AIChE Journal,57( 8), 2198–2206, 2011 |
Conversion of cellobiose into sorbitol in neutral water medium over carbon nanotube-supported ruthenium catalysts | Weiping Deng, Mi Liu, Xuesong Tan, Qinghong Zhang ,, Ye Wang | Journal of Catalysis,271(1), 22-32 2010 |
Effects of acidity and microstructure on the catalytic behavior of cesium salts of 12-tungstophosphoric acid for oxidative dehydrogenation of propane | Jizhe Zhang, Miao Sun, Chuanjing Cao, Qinghong Zhang , Ye Wang, Huilin Wan | Applied Catalysis A, 380(1-2),87-94,2010 |
Dimethyl Ether Catalytic Combustion over Manganese Oxides with Different Structures |
Lin Yu, Gui Qiang Diao, Fei Ye, Ming Sun, Yue Liu, Qian Yu | Advanced Materials Research, 1482, 146-147,2010 |
绿色甲醇:二氧化碳加氢制甲醇之催化剂表征和评价
开放报名!麦克线下进阶培训课(第三期)
开学季,麦克学术资助计划回来了!
开放报名!麦克线下进阶培训课(第三期)
