Particle Size Determination of Porous Powders Using the SediGraph
2009/05/11   下载量: 46
方案下载
应用领域
检测样本
检测项目
参考标准
Sedimentation analysis based upon Stokes’ Law provides a convenient method for determining particle size distribution (PSD). A single solid (or nonporous) sphere settling in a fluid has a terminal settling velocity which is uniquely related to its diameter. The SediGraph determines particle size distributions using the sedimentation method. By measuring the gravity-induced settling velocities of different size particles in a liquid with known properties, the particle sizes are determined. The rate at which nonporous particles fall through a liquid is described by Stokes’ Law
方案下载
配置单
上一篇 超微孔范围内低压、精确的孔隙度测量
下一篇 颗粒分析的准确度对生产过程和最终的产品的影响
文献贡献者
相关方案
当前位置: 美国麦克仪器公司 方案 Particle Size Determination of Porous Powders Using the SediGraph
