Application Note
2008/09/05   下载量: 151
方案下载
应用领域
检测样本
检测项目
参考标准
The unique balanced measurement method used in the Gemini permits small amounts of surface area to be measured with nitrogen gas that otherwise would be measurable only with krypton. Low surface area samples often displace many times more nitrogen than they adsorb, especially if composed of low-density materials of large particle size. The standard, built-in, helium free-space difference measurement and mathematical compensation routine typically can remove the effects of more than 99% of this sample displacement, but the small amount remaining uncompensated can still be significant.
方案下载
配置单
上一篇 超微孔范围内低压、精确的孔隙度测量
下一篇 The PERSEVERANCE of the SEDIGRAPH METHOD of PARTICLE SIZING
文献贡献者
相关方案
当前位置: 美国麦克仪器公司 方案 Application Note
