方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Contact angles are well established as a sensitive means of contamination detection on surfaces. These measurements are straightforward on flat, solid surfaces and can be extended to curved surfaces with a little effort. When the surface is either • rough, e.g., a medium grit sandpaper • a fabric of fibers • perforated with holes
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
