方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
1. In the normal profile mode, where we look sideways at the sessile drop, the FTA200 software should work automatically down to 10° without normal care and down to 5° with special care. Around 5 degrees, one gets "glare" across the top of the drop which confuses automatic analysis. The drop no longer appears as a silhouette against the backlight. 2. Manual analysis, where the user clicks on the drop profile to locate it and the baseline, allows analysis down to, say, 3°。。。。
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
