Contact Angle Measurements on Cotton Fabrics
2010/08/23   下载量: 32
方案下载
应用领域
检测样本
检测项目
参考标准
Cotton sheeting was tested for contact angle and absorption using a customer supplied ink as the test fluid. Two samples were provided: one had a special treatment and the other did not. Small droplets, in the 2 to 3μl volume range, were deposited on the sample by positioning the dispense tip just above the surface and growing the pendant drop until its bottom touched the sample and the drop detached. The image below shows a typical drop just before detachment.
方案下载
上一篇 n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
下一篇 Contact Angles on Lens
文献贡献者
相关方案
当前位置: 林赛斯 方案 Contact Angle Measurements on Cotton Fabrics
