Contact Angles on Lens
2010/08/23   下载量: 28
方案下载
应用领域
检测样本
检测项目
参考标准
Sessile drop contact angles were measured with water on two types of plastic lens with a standard FTÅ200 instrument. One lens had an antireflection coating and the other did not. The purpose of the measurement was to both show the differences between the lens coatings and the process of making measurements on the "side" of a lens where the surface is obviously not flat. A secondary purpose was to see if the curvature of the lens was sufficient that local baseline correction was necessary.
方案下载
上一篇 n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
下一篇 Contact Angle and Surface Tension Measurements of Solders
文献贡献者
相关方案
当前位置: 林赛斯 方案 Contact Angles on Lens
