方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Contact angle measurements can determine the surface energy, γ, of a solid. To accurately measure the surface energy, we must use a set of fluids and the Lewis acid/base theory with the contact angles, θ, for each fluid. However, a simple contact angle measurement with water will give an approximate answer. This is useful because almost all "contaminants" on a surface affect the measured surface energy.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
