接触角测量来表征航空飞机表明镀膜层
2010/08/31   下载量: 83
方案下载
应用领域
检测样本
检测项目
参考标准
Contact angles using water were measured on five coatings used on aircraft. These coatings are very uniform spatially but do exhibit hydration, meaning their contact angle changes as a function of exposure to the vapor of the test fluid (i.e., water). Therefore each contact angle was measured as a function of time, with t = 0 corresponding to the first contact of the water with the dry surface. Two contact angles can be identified: an initial angle and a steady-state angle. These surfaces equilibrated in about 15 seconds, as can be seen from the representative graphs of contact angle versus time presented below.
方案下载
上一篇 n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
下一篇 接触角测量来表征脱模剂
文献贡献者
相关方案
当前位置: 林赛斯 方案 接触角测量来表征航空飞机表明镀膜层
