方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Two injection molded plastic samples were tested for mold release agent. The samples were hemispherical in shape. Contact angles were measured using water and methylene iodide (diiodomethane). The samples had been handled somewhat, so it was not surprising there was some variation in measurements at different locations. Because of this, five measurements of each fluid were made on each sample. The figure below shows a typical drop, in this case methylene iodide on sample #2.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
