方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The FTÅ4000 can place very small drops on a sample and measure the contact angle. To produce small drops, the instrument uses glass capillary needles and a piezo electric pump to control the small volumes required. Two cameras are provided so the user can place the drops at a precise location on the sample. Figure 1 shows a small drop ready to be placed on the sample, which in this case is a printed business card. The width of the printing is measured to illustrate the size of the drop (in the bottom of the "2"). The instrument can produce drops which are considerable smaller than the one illustrated, but then the "weave" or roughness of the paper becomes an issue in making contact angle measurements.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
