方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Contact angles are well established as a sensitive means of contamination detection on surfaces. These measurements are straightforward on flat, solid surfaces and can be extended to curved surfaces with a little effort. When the surface is either • rough, e.g., a medium grit sandpaper • a fabric of fibers • perforated with holes then it is composite in the sense that it alternates between air and substrate as one moves microscopically across the surface. It is important to understand that the contact angles reflect the composite material and not just the original solid substrate.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
