方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Cotton sheeting was tested for contact angle and absorption using a customer supplied ink as the test fluid. Two samples were provided: one had a special treatment and the other did not. Small droplets, in the 2 to 3μl volume range, were deposited on the sample by positioning the dispense tip just above the surface and growing the pendant drop until its bottom touched the sample and the drop detached. The image below shows a typical drop just before detachment.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
