方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
This sample exhibited an equilibrium water contact angle of zero degrees, but the spreading is not instantaneous. The FTÅ200 can measure this spreading time. The following figures illustrate the drop profile at various times. The resultant contact angle and base width is also graphed. Differing amounts of surfactant in the resin would cause the drop to spread at different rates. To do comparative work of this nature, the drop volume should be standardized to within, say, 10% on each sample. The pump forms a pendant drop on the tip which is allowed to grow until its bottom touches the surface, at which time the drop detaches from the tip and forms a sessile drop.
n型Sb合金SnSe热电多晶中纳米结构和导热系数降低的证据
用于太阳能集热器的具有增强热性能和机械性能的石墨烯结合铝
塑料共混物对油棕空果串慢速热解的影响
