方案下载应用领域 | 农/林/牧/渔 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 向日葵细胞悬浮培养 |
The cultivation of Helianthus annuus suspension cultures in single‐use bioreactors of different culture volume should be adapted and established by determining process parameters. A comparison with the cultivation attempts conducted by the TU Dresden (Geipel, Werner) should point out the advantages and disadvantages of the culture systems concerning growth rate and foam generation.
The cultivation of plant cells continuously became more important in the last years due to a high amount of different substances which could be used by the pharmaceutical and cosmetic industry. However, during cultivation of plant suspension foam generation and shear stress occurs which may have negative effect on cell
growth. In addition, cell growth, aggregation and the release of exopolysaccarides lead to a continuous change of the rheological behaviour, which requires constant process adjustment.
Besides STR’s (stirred tank reactor), disposable (single‐use) systems such as the Biostat CultiBag RM, which is well established in cultivation volumes of 2 to 20 L, are used for plant cell cultivation. By inducing an orbitally shaking motion or a wave‐mixed motion, mixing is achieved and oxygen is transferred from the aerated reactor chamber into the culture medium.
波清洗器在化妆品中尿素含量的测定 酶催化法中的作用
通用水浴槽在饮料中微生物的检验(滤膜前处理法)中的作用
干燥箱在橡胶中异丁-异戊二烯橡胶或聚异丁烯含量的检测中的应用
WIGGENS DIGICEN 21R 程序控制离心机
WIGGENS WF-10G 强制对流干燥箱
WIGGENS C602防腐蚀隔膜真空泵
WIGGENS WH200D-2K 数字式加热板
WAGGENSThomson高效培养瓶
WIGGENS WB1800-EC/WB3000-EC分体式高速大扭距搅拌器
WIGGENS WUS22 超声波振荡水浴
WIGGENS E系列废液储存罐
WIGGENS VOYAGEUR生物制品冻存运输罐
WIGGENS GT系列生物制品液氮冻存罐
WIGGENS 1301-1305全自动液氮液位控制系统
WIGGENS 制冷型超声波恒温浴槽
WIGGENS Wtherm加热浴槽 / 恒温循环器
WIGGENS WS20 振荡水浴槽/ 恒温培养摇床
WIGGENS MB800 组织捣碎机
