方案下载应用领域 | 电子/电气 |
检测样本 | 其他 |
检测项目 | |
参考标准 | Tin telluride Nanoparticle Nanometer size effect Thermoelectric property Microwave hydrothermal method |
SnTe is a notable member of the IV–VI semiconductors with SnSe and PbTe as two representative thermoelectric materials, which is considered to be a potentially attractive thermoelectric material due to its similar rock-salt crystal structure to PbTe. However, the current researches on SnTe are limited because of the difficult synthesis in aspect of controlling morphology and size, and its thermoelectric figure of merit is also low due to the high thermal conductivity. In this study, a simple and ultra-fast microwave hydrothermal method was designed to synthesize the SnTe particles with controlled sizes from micro-scale to nano-scale. The thermoelectric properties of the corresponding SnTe bulk materials prepared by spark plasma sintering were investigated in a wide temperature range with a focus on the size effect. Due to the enhanced phonon scattering caused by the nanometer size effect, a low thermal conductivity, 0.60 W m1 K1 at 803 K, was obtained in the bulk specimen using 165-nm-sized nanoparticles. The corresponding maximum ZT value at 803 K is enhanced to 0.49, which is about 2.3 times that of the SnTe bulk samples using mechanically alloyed powders. & 2016
微波辅助分子内酯交换法合成环收缩红霉素A衍生物
超声与微波协同作用对转谷氨酰胺酶交联的乳清蛋白结构和功能特性的影响
微波辅助合成的新型类固醇希夫碱化学传感器用于检测水介质中的Al3+。
