方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The apparent acid dissociation constants (psKa) of two water-insoluble drugs, ibuprofen and quinine, were determined pH-metrically in acetonitrile–water, dimethylformamide–water, dimethylsulfoxide–water, 1,4-dioxane– water, ethanol–water, ethylene glycol–water, methanol–water and tetrahydrofuran–water mixtures. A glass electrode calibration procedure based on a four-parameter equation (pHaSpcHjH[H]jOH[OH]) was used to obtain pH readings based on the concentration scale (pcH). We have called this four-parameter method the Four-Plus™ technique. The Yasuda–Shedlovsky extrapolation (psKalog [H2O]A:oB) was used to derive acid dissociation constants in aqueous solution (pKa). It has been demonstrated that the pKa values extrapolated from such solvent–water mixtures are consistent with each other and with previously reported measurements. The suggested method has also been applied with success to determine the pKa values of two pyridine derivatives of pharmaceutical interest. © 1999 Elsevier Science B.V. All rights reserved.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
