方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A multiwavelength spectrophotometric (WApH) titration method for determination of acid dissociation constants (p Κa values) of ionisable compounds developed previously was applied in the case of pyridine derivatives of pharmaceutical interest. Specifically, UV absorption spectra of the drug solution are acquired in the course of a pH-metric titration using an optical device based on a fibre optics dip probe, a light source and diode array detector. Target factor analysis was applied to deduce the p Κa values from the spectral data recorded at different pH. Using this technique, the p Κa values of six pyridine derivatives were determined successfully. It was demonstrated that the WApH technique in this case outperforms conventional pH-metric methods with respect to the measurement of p Κa values of the sparingly water soluble samples reported in this study. 1999 Elsevier Science B.V. All rights reserved.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
