方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
are two possibilities; external and internal pressure. The battery being self contained will show no external pressure until release of a venting disc or disintegration, the gas released will react with oxygen in the environment. Such tests may simply be carried out by enclosing the battery in a holder. Earlier reported tests used a heavy close fitting container, such a holder compromises thermal data and might explode upon rapid gas release. The usefulness of this data might be questioned since there would be no pressure rise from the start of the test until battery ‘opening’ occurs and then there would be a simple single rapid pressure rise. Perhaps of more interest is the development of internal pressure, how this increases with temperature and the temperature and pressure that can be withstood before opening. For the first time we report calorimetric (thermal and pressure) data and though not shown here associated electrical data (voltage) can be recorded throughout the test. Tests have been carried out with ‘specimen’ 18650 batteries. For the test protocol, minor modifications are necessary to the ARC and to the battery itself. Here is reported the set up protocol, the experimentation and results.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
