方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
BACKGROUND: Various methods, including centrifugation, filtration, electroflocculation, flocculation and flotation, have been developed for harvesting microalgae. However, some economic or technical problems still remain with current methods for algal recovery, such as high capital, energy and running costs, flocculant toxicity or low separation efficiency. Therefore, there is great interest in developing new efficient approaches for harvesting microalgae. RESULT: An efficient electroflocculation method integrated with dispersed-air flotation has been developed for harvesting Botryococcus braunii. The recovery efficiency of B. braunii reached 93.6% after 30min using an electroflocculation process. Microalgae recovery was improved significantly when the electroflocculation process was integrated with dispersed-air flotation; the recovery efficiency of B. braunii reached 98.9% after 14min. CONCLUSION: The present work demonstrated that electroflocculation integrated with dispersed-air flotation is a promising method suitable formicroalgae harvesting. The strategic air supply obviously shortened the algal recovery time in the process of electroflocculation due to facilitating algal aggregation and flotation to the solution surface.
薄膜过滤法菌落自动计数解决方案
薄膜过滤法菌落自动计数解决方案
薄膜过滤法菌落自动计数解决方案
HD2000(AI)智能菌落计数仪
迅数icount 11 全自动菌落计数仪
迅数M600菌落计数/浮游生物分析联用仪
迅数Z10抑菌圈(抗生素效价)测量仪
Czone 9 / Czone 9 pro菌落计数及抑菌圈测量仪
迅数icount 22 全自动菌落计数仪
迅数icount 33全自动菌落计数仪
Supcre G10(AI) 菌落计数/筛选/抑菌圈测量联用仪
迅数icount 60/ icount 60pro全自动菌落计数仪
HD5000(AI)多谱超分辨菌落成像系统
迅数Z9/Z9 Plus抑菌圈(抗生素效价)测量仪
Supcre G9菌落计数/筛选/抑菌圈测量联用仪
迅数MF4菌落计数/显微分析多功能联用仪
迅数icount 50全自动菌落计数仪
迅数Czone 8菌落计数及抑菌圈测量仪
