方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 无 |
采用安东帕微波消解仪配备微波氧燃烧技术样品处理,采用ICP-MS检测,对氟塑料中Ag, Ca, Cd, Co, Cr, Cu, Fe, K, Mg, Mn, and Ni 痕量元素进行检测。
An effective approach to the digestion of fluoropolymers for the determination of Ag, Ca, Cd, Co, Cr, Cu, Fe, K, Mg, Mn, and Ni impurities has been developed using microwave-induced combustion (MIC) in closed quartz vessels pressurized with oxygen. Samples that were examined included the following: polytetrafluorethylene (PTFE); polytetrafluoroethylene with an additional modifier, perfluoropropylvinylether (PTFE-TFM); and fluorinated ethylene propylene (FEP). A quartz device was used as a sample holder, and the influence of the absorber solution was evaluated. Determination of trace elements was performed by inductively coupled plasma−optical emission and mass spectrometry. Neutron activation analysis (NAA) was used for validation purposes. Results were also compared to those obtained using microwave-assisted acid extraction in high-pressure closed systems. Dilute nitric acid (5 mol L−1), which was selected as the absorbing medium, was used to reflux the sample for 5 min after the combustion. Using these conditions, agreement for all analytes was better than 98% when compared to values determined by NAA. The residual carbon content in the digests was lower than 1%, illustrating the high efficiency of the method. Up to 8 samples could be digested within 30 min using MIC, providing a suitable throughput, taking into account the inertness of such samples.
MultiWave PRO 微波消解铂依合金
煤炭中硒含量的测定
重水含量或纯度的鉴定
安东帕康塔全自动比表面和孔径分布分析仪Autosorb-iQ
安东帕康塔比表面和孔径分析仪:Nova系列
安东帕Anton Paar粘度计SVM 1001
安东帕Anton Paar啤酒分析系统Alcolyzer Beer Analyzing System
安东帕Anton Paar全自动成品啤酒分析系统PBA 5001 Beer
纳米压痕测试仪:Hit 300
安东帕自动化多用途粉末X射线衍射仪
SAXS/WAXS/GISAXS/RheoSAXS 实验室光束线装置
紧凑型拉曼光谱仪Cora 5001
安东帕多参数分析系统:Modulyzer
安东帕Anton Paar在线二氧化碳传感器Carbo
安东帕Anton Paar低温冰粘密浊多功能测定仪SVM 3001
安东帕Anton Paar饮料色度传感器L-Col
安东帕L-Dens 2300 密度传感器
安东帕Anton Paar在线声速传感器L-Sonic
