运用多种技术测试的Porous Ceramic TiO2 的完整特性
2005/01/11   下载量: 19
方案下载
应用领域
检测样本
检测项目
参考标准
In order to achieve a comprehensive characterization of porous materials a combination of different experimental techniques is necessary. This is illustrated by applying a number of different measuring techniques including gas sorption,, mercury porosimetry, scanning electronic microscopy , laser diffraction, and pycnometry to a well-defined, porous ceramic TiO2 material (Sachtopore [1,2]) designed for chromatography by Sachtleben Chemie GmbH (Germany). These porous TiO2 materials are intended for use in both, analytical and preparatory applications, and can be synthesized with different particle sizes (3, 5, 10, 20, and 40 m) and (controlled) pore sizes ( 6 to 200 nm).
方案下载
上一篇 蔗糖和工业用糖的表观纯度解决方案
下一篇 界面流变测量技术
文献贡献者
相关方案
当前位置: 安东帕 方案 运用多种技术测试的Porous Ceramic TiO2 的完整特性
