方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A state of the art anode for the solid oxide fuel cell (SOFC) consists of a mixture of 8 mol% Y2O3-stabilized zirconia (8YSZ) and nickel particles, which form an interconnected porous structure after sintering. Coarsening of the Ni particles under SOFC working conditions has to be avoided, hence it leads to a deterioration of the anode’s performance. In the present work the aim was to improve the stability of the Ni particles by a reduction of the sintering activity of nickel. For this purpose between 10 and 50% by volume of nano-sized zirconia particles have been dispersed in the nickel matrix by dry ball milling in a planetary mill. For pressed samples made of mechanically alloyed Ni with 10 vol% of 8YSZ, a homogeneous dispersion of 8YSZ particles in the Ni matrix was confirmed by transmission electron microscopy. It was confirmed by mercury porosity penetration and optical microscopy that this dispersoid structure leads to a retardation of recrystallization.
PFA超高纯电子级试剂包装瓶-G5级湿电子化学品包装
LabAnalyzer 254 汞分析仪
VM-300O、Lab-254用于煤燃烧过程中汞的监测控制.pdf
ICP-MS PFA惰性进样套件 兼容PE NexION 300系列
PFA质谱惰性进样套件 兼容Thermo Element 2/Nept
PFA惰性进样套件 兼容安捷伦7500/7700/78x0x系列
酸逆流清洗机savillex美国VC Ultra酸蒸清洗器
PURELAB® Quest 纯水机
PURELAB Micra系列 纯水机
PURELAB flex系列 纯水机
PURELAB Classic系列 纯水机
ELGA 实验室中央纯水系统CENTRA
ELGA纯水机 PURELAB® Chorus系列
MULLER-BBM MACOM II ®主动磁场补偿系统
烟囱气体汞监测仪SM-4 Mobile
便携式总烃监测仪OVF3000
超低流量加热型SHED FID总烃监测仪
便携式汞分析仪Traker 3000XS
