方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
SIMULTANEOUS OPTICAL MEASUREMENT OF PARTICLE SIZE AND SHAPE Bernhard Michel, Scientific Consulting, Am Steinbruch 1, D-91126 Rednitzhembach, Germany Wolfgang Mutter, Fritsch GmbH, Industriestrasse 8, D-55743 Idar-Oberstein, Germany Abstract. Conventional optical particle sizers evaluate the dependence of scattered light on the polar angle (angle relative to the optical axis) in order to determine size distributions of particles. The dependence on the azimuth angle (around the optical axis) commonly is not considered, although it contains valuable information about particle shape. We present a novel optical particle analyzer developed by Fritsch GmbH, which is based on an inverse Fourier setup. It uses a custom-made silicon sensor to detect the dependence of the scattered light on both polar and azimuth angle, thus enabling the simultaneous determination of particle size and shape. The particle shape analysis is currently restricted to the Fraunhofer regime, starting with a minimum size of 3 μm. For the particle size measurement, small- and wide-angle light scattering is evaluated, leading to a possible dynamic range from 10 nm up to 2 mm. The main advantages of the new particle analyzer are its cost-efficiency, because it is an all-in-one solution,
LabAnalyzer 254 汞分析仪
VM-300O、Lab-254用于煤燃烧过程中汞的监测控制.pdf
VM-3000、Lab-254 用于煤燃烧和环境保护的研究
ICP-MS PFA惰性进样套件 兼容PE NexION 300系列
PFA质谱惰性进样套件 兼容Thermo Element 2/Nept
PFA惰性进样套件 兼容安捷伦7500/7700/78x0x系列
酸逆流清洗机savillex美国VC Ultra酸蒸清洗器
PURELAB® Quest 纯水机
PURELAB Micra系列 纯水机
PURELAB flex系列 纯水机
PURELAB Classic系列 纯水机
ELGA 实验室中央纯水系统CENTRA
ELGA纯水机 PURELAB® Chorus系列
MULLER-BBM MACOM II ®主动磁场补偿系统
烟囱气体汞监测仪SM-4 Mobile
便携式总烃监测仪OVF3000
超低流量加热型SHED FID总烃监测仪
便携式汞分析仪Traker 3000XS
