方案下载应用领域 | 食品/农产品 |
检测样本 | 畜禽肉及副产品 |
检测项目 | 营养成分>产品品质等级 |
参考标准 |
An investigation was conducted to evaluate the capacity of an electronic metal oxide semiconductor (MOS)-type nose (e-nose) to classify pork samples with different storage times (0–6 d). The effects of the headspace-generation time and pork sample mass on the response of the e-nose were studied using multivariate analysis of variance and oneway analysis of variance, respectively. The results showed that the pork sample mass had the most significant effect on the e-nose sensor response, followed by the headspacegeneration time. The optimum parameters were 10 g of sample mass with 5 min of headspace-generation time in a 500 mL vial. After either principal component analysis or linear discriminant analysis, the results showed that the e-nose with the optimum parameters can accurately classify the pork samples stored for 0–6 d. A method using a back propagation neural network was also performed, and 91.43% of the prediction set (with 92.86% of the training set) was classified correctly using this model.
电子舌用于检测某干混悬剂味觉检测
通过电子鼻和电子舌关联性对不同口味绿茶苦味和涩味的检测
福建农林大学科研团队揭示铁观音风味物质空间分布研究最新成果
