方案下载应用领域 | 食品/农产品 |
检测样本 | 茶叶 |
检测项目 | 营养成分>产品品质等级 |
参考标准 |
Sensory evaluation can provide integrated, direct measurements of the perceived quality of food products. However, a sensory panel is subjective and suffers from inconsistency and inaccuracy. In this paper, we propose a sensory evaluation simulation model for Longjing tea (a Chinese brand of green tea). The physiochemical quality indicators of Longjing tea were determined by instrumental analysis, including color, aroma, and taste. Meanwhile, the sensory quality of the tea was evaluated by an expert sensory panel. An artificial neural network was conducted to approximately predict sensory evaluation scores on the basis of physiochemical data. The results showed that physiochemical factors, including hue, fluorescence peak 5, hue chromascale, b, L, 3-(methylthio) propionaldehyde, α-terpineol, linalool, dimethyl sulfide, total aroma value, caffeine, quinic acid, theanin, gallic acid and total catechins were best correlated with sensory evaluation scores. Furthermore, physiochemical features that were chosen according to important factor weights were used to classify Longjing tea into two grades. Experimental results demonstrated that instrumental analysis could be complementarily used in the evaluation and control of sensory quality by establishing a reasonable sensory-instrument correlation and human-simulated predictive model.
电子舌用于检测某干混悬剂味觉检测
通过电子鼻和电子舌关联性对不同口味绿茶苦味和涩味的检测
福建农林大学科研团队揭示铁观音风味物质空间分布研究最新成果
