方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | ASTM D5865 |
用力可AC600量热仪,苯甲酸为标样分析 The gross calorific value of coal, a solid fossil hydrocarbon fuel material, is most often used when calculating the total calorific value for a quantity of coal for fuel value purposes, or when determining the classification rank of the coal material. The gross calorific value and sulfur value of the coal material can also be used to calculate whether or not the coal material meets regulatory requirements for industrial fuel use.
使用美国力可公司LECO AC600量热仪 分析煤炭中热量值,采用ASTM D5865标准方法,获得良好结果
凯氏定氮与杜马斯定氮—概述和比较
力可LECO TGA801热重分析仪分析植物组织中水分挥发分和灰分
力可LECO SC832碳硫分析仪分析
