方案下载应用领域 | 钢铁/金属 |
检测样本 | 铁 |
检测项目 | 含量分析>硫元素, 碳元素 |
参考标准 | 铁合金中低碳低硫检测 |
Ferroalloys are alloys of iron that contain a high level of one or more other primary elements. The principle ferroalloys consist of silicon, manganese, and chromium that are used as vehicles to introduce the alloying element into the molten metal when making steel or cast iron. For example, silicon is used to deoxidize steel and as an alloying element in cast iron. Manganese is used as an alloying element and mitigates the harmful effects of sulfur in cast iron and steel. Chromium increases corrosion resistance in stainless steels. Since carbon is the most important alloying constituent in steel and cast iron production, and sulfur is a harmful contaminant that negatively affects the mechanical properties of steel and cast iron, the determination of carbon and sulfur levels in the ferroalloy feed stock is a critical quality control parameter.
采用力可公司 LECO CS844碳硫分析仪分析铁合金中的低碳和低硫含量,获得满意的结果
凯氏定氮与杜马斯定氮—概述和比较
力可LECO TGA801热重分析仪分析植物组织中水分挥发分和灰分
力可LECO SC832碳硫分析仪分析
