方案下载应用领域 | 建材/家具 |
检测样本 | 耐火耐腐材料 |
检测项目 | |
参考标准 | 非分散红外吸收法 |
Oxides are abrasive, and cause damage to the pumps and nozzles of high speed/volume solder equipment. Excessive oxide content is also known to cause grainy or dull solder joints, with poor electrical and mechanical properties. LECO 736 series oxygen determinators, which detect oxygen as CO , will quickly and accurately determine 2 the amount of oxygen present in tin and lead-based solder powders.
利用力可LECO ON736氧氮分析仪分析锡和铅基焊料粉中氧含量,获得如下结果,重复性和短期长期精度极好,详细方法请见附件:
凯氏定氮与杜马斯定氮—概述和比较
力可LECO TGA801热重分析仪分析植物组织中水分挥发分和灰分
力可LECO SC832碳硫分析仪分析
