方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The development of a rapid, accurate and cost-effective method for the prediction of constituents related to soil nitrogen (N) supply is considered important. The potential of using visible (Vis) and near infrared reflectance (NIR) spectroscopy (400–2500 nm) as such a method was investigated. Vis–NIR calibrations were performed for organic carbon (Corg) and total N (Ntot) content and their potential mineralisation using 80 grassland soil samples of rather heterogeneous origin. Prediction accuracy was tested using a ‘take-out-four’ validation strategy (48 samples).Within investigated variables a ratio of standard deviation of reference data to standard error of bias corrected prediction (RPD) within 1.7 (r2 = 0.65) and 2.7 (r2 = 0.87) were achieved. Apparent differences........
万能食品研磨机
陶瓷材料如何进行研磨呢
木质材料精细研磨的最佳解决方案
