方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Nickel oxide-modified polymeric composite electrodewas prepared for electrochemical detection in liquid chromatography (LC-ECD) or flow injection analysis of polyhydroxyl compounds. The composite electrode was prepared by incorporating semigraphitic carbon black and nickel oxide particles in polystyrene polymer matrix cross-linked with divinylbenzene. The analytical characteristics of the electrodes in LC-ECD and flow injection analysis of polyhydroxyl compounds were evaluated in terms of sensitivity, reproducibility, stability and surface renewability. The electrode revealed three–four orders of dynamic concentration ranges from sub-micromolar to 10−3Mwith high correlation coefficients from 0.9998 to 0.9999 for various polyhydroxyl compounds. The standard deviation for the surface restoration was <2%. High reproducibility, stability, and the renewability of surface are thought to be due to the catalyst particles highly dispersed through robust polymeric electrode matrix. © 2002 Elsevier Science B.V. All rights reserved
山东省科学院生物所:还原糖测定仪与人工滴定法分析蔗汁还原糖含量的比较
山东省科学院生物所:熟地黄炮制过程中还原糖的快速测定
山东省科学院生物所:发酵生产中还原糖和葡萄糖检测指标的分析
