方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract: High-speed counter-current chromatography (HSCCC) coupled with evaporative light scattering detection (ELSD) was successfully applied to preparative separation and purification of verticine and verticinone from crude extracts of Bulbus Fritillariae Thunbergii by a one-step separation,using chloroform–ethanol–0.2 mol L−1 hydrochloric acid (3:2:2, v/v/v) as a solvent system. HPLC analysis of the fractions collected on the preparative HSCCC of 200 mg of crude extracts showed that the purity of verticine (25.6 mg) was 96.8% and that of verticinone (10.3 mg) was 95.4%. The chemical identities of these components were confirmed by H-NMR and EI-MS.
上海同田生物技术:运用高速逆流色谱法从仙茅中分离仙茅甙和仙茅甙乙
上海同田生物技术:高速逆流色谱法分离制备丹酚酸B
