方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
利用HS-SPDE/GC/MS/MS技术测定头发中毒品含量。A new method combination, headspace solid-phase dynamic extraction coupled with gas chromatography/ tandem mass spectrometry (HS-SPDE/GC/MS/MS), is introduced to determine drugs of abuse in hair samples. This highly automated procedure utilizes SPDE for pre-concentration and on-coating derivatization as well as GC and triple quadrupole MS/MS for selective and sensitive detection. All these steps, apart from washing and cutting of the hair samples, are performed without manual intervention on a robot-like autosampler. SPDE is a solventless extraction technique related to solid-phase microextraction (SPME). The analytes are absorbed from the sample headspace directly into a hollow needle with an internal coating of polydimethylsiloxane by repeated aspirate/dispense cycles. The HS-SPDE/GC/MS/MS procedure was applied to the analysis of methadone, the trimethylsilyl derivatives of cannabinoids and the trifluoroacetyl derivatives of amphetamines and designer drugs. The method was shown to be sensitive with detection limits between 6 and 52 pg/mg hair matrix and precision between 0.4 and 7.8% by the use of an internal standard technique. Linearity was obtained from 0.1–20 ng/mg with coefficients of correlation between 0.995 and 0.999. Compared with conventional methods of hair analysis, HS-SPDE/GC/MS/MS is easier to use, substantially faster, with the degree of sensitivity and reproducibility demanded in clinical and forensic toxicology. The main advantage of the SPDE technique in relation to SPME is the robustness of the capillary. Copyright # 2003 John Wiley & Sons, Ltd.
联和层析:ITEX用于检测饮用水中VOCs
双臂多功能进样器
在线SPE,在线固相萃取
RTC 全自动气相液相进样器
PAL3 气相液相色谱通用多功能自动进样平台
PAL 多种多样的选件: 功能模块、切换阀组与控制软件
Dynamic Load and Wash 动态洗针快速进样功能
液质全自动在线固相微萃取
液质血液样品自动化进样平台
OPTIC 4多模式进样口
气相色谱多功能自动进样器 ITEX-2微管捕集模块
瑞士CTC多功能进样器 Combi-PAL 液体/顶空/固相微萃取/ITEX
瑞士CTC HTC-PAL液相/液质连用多功能自动进样器
英国CSI 快速气相色谱仪
英国CSI TEA610 热能分析仪(原Thermo Electron厂牌)
热脱附多功能全自动进样器
SPDE固相动态萃取多功能全自动进样器
GC-PAL 气相色谱及质谱连用(GC-MS)液体进样器系统
