Q8/UV测试方法
通用 | | ISO 4892-1 Plastics- Methods of exposure to laboratory light sources-Part 1: General Guidance ASTM G-151, Standard Practice for Exposing Nonmetallic Materials in Accelerated Test Devices that Use Laboratory Light Sources ASTM G-154, Standard Practice for Operating Fluorescent Light Apparatus for UV Exposure of Non-Metallic Materials British Standard BS 2782: Part 5, Method 540B (Methods of Exposure to Lab Light Sources) SAE J2020, Accelerated Exp. of Automotive Exterior Materials Using a Fluorescent UV/Condensation Apparatus JIS D 0205, Test Method of Weatherability for Automotive Parts (Japan) GB/T 16422.1,塑料实验室光源暴露试验方法 第1部分:总则
涂料 | | ISO 11507, Paints & varnishes-Exposure of coatings to artificial weathering-Exposure to fluorescent UV and water ISO 20340, Paints & varnishes –Performance requirements for protective paint systems for offshore and related structures ASTM D-3794, Standard Guide for Testing Coil Coatings ASTM D-4587, Standard Practice for Light/Water Exposure of Paint US Government, FED-STD-141B US Govt., Federal Specification TT-E-489H, Enamel, Alkyd, Gloss, Low VOC Content US Govt., Federal Specification TT-E-527D, Enamel, Alkyd, Lusterless, Low VOC Content US Govt., Federal Specification TT-E-529G, Enamel, Alkyd, Semigloss, Low VOC Content US Govt., Federal Specification TT-P-19D Paint, Latex, Acrylic Emulsion, Ext. Wood & Masonry NACE Standard TM-01-84 Procedures for Screening Atmospheric Surfaced coatings www.hongzhangroup.com GM4367M Topcoat Materials - Exterior GM 9125P Laboratory Accelerated Exposure of Automotive Material Korean Standard M5982-1990, Test Method for Accelerated Weathering Spanish Std, UNE 104-281-88 Accelerated Testing of Paints and Adhesives with Fluorescent UV Lamps Israeli Standard No. 330, Steel Windows Israeli Standard No. 385, Plastic Windows Israeli Standard No. 935, Road Marking Paint Israeli Standard No. 1086, Aluminum Windows NISSAN M0007, Fluorescent UV/Condensation Test JIS K 5600-7-8, Testing Methods for Paints MS 133: Part F16, Methods of Test for Paints and Varnishes: Part F16: Exposure of Coatings to Artificial Weathering- Exposure to Fluorescent UV and Water (ISO 11507) NBR-15.380 Paints for buildings–Methods for performance evaluation of paints for non-industrial buildings – Resistance to UV irradiation/water vapor condensation, by accelerated test prEN 927-6 Paints & varnishes–Coating materials and coating systems for exterior wood – Pt. 6: Exposure of wood coatings to artificial weathering using fluorescent UV and water GB/T 12967.4,铝及铝合金阳极氧化 着色阳极 氧化膜耐紫外光性能的测定
纺织品 | | AATCC Test Method 186, Weather Resistance: UV Light and Moisture Exposure ACFFA Test Method for Colorfastness of Vinyl Coated Polyester Fabrics
橡胶 | | ? GB/T 16585,硫化橡胶人工气候老化(荧光紫外灯)试验方法 |
电工电子产品 | | ? GB/T 19394,光伏(PV)组件紫外试验 | type the link here
粘合剂和密封剂 | | ASTM C 1501, Standard Test Method For Color Stability of Building Construction Sealants as Determined byLaboratory Accelerated Weathering Procedures ASTM C-1184, Specification for Structural Silicone Sealants ASTM C-1442, Standard Practice for Conducting Tests on Sealants Using Artificial Weathering Apparatus ASTM D-904, Standard Practice for Exposure of Adhesive Specimens to Artificial Light ASTM D-5215, Standard Test Method for Instrumental Evaluation of Staining of Vinyl Flooring by Adhesives American Plywood Assn., Approval Procedures for Synthetic Patching Materials, Section 6 Spanish Std, UNE 104-281-88 Accelerated Testing of Paints and Adhesives with Fluorescent UV Lamps
塑料 | | ISO 4892 Plastics - Methods of Exposure to Laboratory Light Sources-Part 3: Fluorescent UV Lamps DIN 53 384, Testing of plastics, Artificial Weathering and Exposure to Artificial Light Spanish Standard UNE 53.104 (Stability of Plastics Materials Exposed to Simulated Sunlight) Israeli Standard No. 385, Plastic Windows www.hongzhangroup.com JIS K 7350, Plastics - Methods of Exposure to Laboratory Light Sources-Part 3: Fluorescent UV Lamps ASTM D-1248, Standard Specification for Polyethylene Plastics Extrusion Materials for Wire and Cable ASTM D-4329, Standard Practice for Light/Water Exposure of Plastics ASTM D-4674, Test Method for Accelerated Testing for Color Stability of Plastics Exposed to Indoor Fluorescent Lighting and Window-Filtered Daylight ASTM D-5208, Standard Practice for Exposure of Photodegradable Plastics ASTM D-6662, Standard Specification for Plastic Lumber Decking Boards ANSI C57.12.28 Specification for Accelerated Weathering of Padmounted Equipment Enclosure Integrity ANSI, A14.5 Specification for Accelerated Weathering of Portable Reinforced Plastic Ladders Edison Electrical Inst. Specification for Accelerated Weathering of Padmounted Equip. Enclosure Integrity Wisconsin Electric Power Specification for Polyethylene Signs GB/T 18950,橡胶和塑料软管 静态下耐紫外线性能测定 GB/T 16422.3,塑料实验室光源暴露试验方法 第3部分:荧光紫外灯
屋顶材料 | | ASTM D-4799, Test Method for Accelerated Weathering of Bituminous Roofing Materials ASTM D-4811, Standard Specification for Nonvulcanized Rubber Sheet Used as Roof Flashing ASTM D-3105, List of Test Methods for Elastomeric and Plastomeric Roofing & Waterproofing ASTM D-4434, Standard Specification for PVC Sheet Roofing ASTM D-5019, Standard Specification for Reinforced Non-Vulcanized Polymeric Sheet Used in Roofing Membrane ANSI/RMA IPR-1-1990 Req. for Non-Reinforced Black EPDM Sheet for Roofing Membrane ANSI/RMA IPR-2-1990 Req. for Fabric-Reinforced Black EPDM Sheet for Roofing Membrane ANSI/RMA IPR-5-1990 Req. for Non-Reinforced Non-Black EPDM Sheet for Roofing Membrane ANSI/RMA IPR-6-1990 Req. for Fabric-Reinforced Non-Black EPDM Sheet for Roofing Membrane British Standard BS 903: Part A54 Annex A & D, Methods of Testing Vulcanized Rubber CGSB-37.54-M, Canadian General Standards Board Spec. for PVC Roofing & Waterproofing Membrane DIN EN 534, Corrugated bitumen sheets EOTA TR 010, Exposure procedure for artificial weathering RMA Specification for Reinforced Non-Vulcanized Chlorosulfonated Polyethylene Sheet for Roofing Membrane
复合材料 | | |
