Thermally stimulated current method
2007/07/05   下载量: 84
方案下载
应用领域
检测样本
检测项目
参考标准
We propose an improved method for the analysis of Thermally Stimulated Currents (TSC) measured on highly irradiated silicon diodes. The proposed TSC formula for the evaluation of a set of TSC spectra obtained with different reverse biases leads not only to the concentration of electron and hole traps visible in the spectra but also gives an estimation for the concentration of defects which not give rise to a peak in the 30–220K TSC temperature range (very shallow or very deep levels). The method is applied to a diode irradiated with a neutron fluence of fn ¼ 1:82  1013 n/cm2.
方案下载
上一篇 STA表征硫化橡胶组分含量
下一篇 Thermally stimulated current in SiO2
文献贡献者
相关方案
当前位置: 塞塔拉姆SETARAM 方案 Thermally stimulated current method
